1 - 4 of 4 Posts
i have xr70 forks on my 50 and i have drum brakes i cant stand them anymore does any1 now if i can get disk brakes for it the drum brake is just not working right where the 10in wheel is on the 70 forks
thanks
IDK but I think not...you will have to change to a fork leg that has a caliper mount...there is a disc brake conversion for 50 forks but idk about 70 forks....you can put a china front end on for cheap
I am gonna be putting 70 forks on my daughters 50 in a couple of days...I know you have to make a special bracket for the brake cable but not a big deal...like I said, I know they make a cable actuated disc brake kit that fit the 50 OEM hub but I have only seen that with OEM 50 forks..IDK if they make one like that for a 70....otherwise it is change the forks out with something with disc already on it....
1 - 4 of 4 Posts
