the air does make it adjustable, but not how you would think it would... the air chamber is used to work in conjunction with the dampening and not the compression so it is not like a fox shock that has a air spring. The RB's have a coiled spring on one side and on the other is the air/rebound compession; the air does not affect the compression like a fox does, if it did they would be awesome. Pretty good fork if you get a set that don't pop the un-servicable rebound/compression seals; I have had 3 sets but will get Zokes next time.
