SOLD
This motor has seen less than an hour of use as the kickstart rod snapped prior to a race. The motor was swapped with the backup motor to continue on and the backup motor (same motor) has been in the chassis ever since. The motor will bump start and run without issue, the tip of the metal rod where your start lever attaches just snapped when kicking over. I have a new kickstart assembly and gasket set for it, splitting the cases is required.
Located in Goodyear, AZ
$450 shipped.
714-478-7088
Josh
$450 shipped.
714-478-7088
Josh
