CT70 pipe and carb question
986 Views 3 Replies 2 Participants Last post by  Z
Is a 20mm carb and aftermarket pipe to much for a stock ct70?
Mike
1 - 4 of 4 Posts
The 20mm carb will be slighly large for a stock CT70. Install an 88cc BBK and you'll have some good gains considering the CT70 head is a good one.
Do the BB kits work good with the stock cam or should I go for the aftermarket cam too?
Mike
They will work fine with the stock CT70 cam, but you'll realize a ton more gains with the aftermarket cam. Just make sure you get the cam to match your head. If you have a 6v CT70, you'll need a non-rollerbearing cam.
1 - 4 of 4 Posts
