1 - 3 of 3 Posts
I’m doing a complete tear down and rebuild of a KO CT70 engine and I’m finally getting all the parts I need for this rebuild. The original clutch plates looked pretty whipped and I decided not to take any chances and order new springs, plates and of course the friction plates. When I received the plates I noticed that plate B looks different. I looked on the NEV site and this plate is listed for KO but Dr. ATV shows as K1 and newer. I’m thinking this plate is fine and Honda has re-designed it over the years but I was hoping to get some confirmation from this forum if it’s ok to use this new plate. Inhave attached a pick. Thanks again for all your help.
Yes, there are three disc and five disc set-ups for these clutches and differences in the plates. Both will work. You should be just fine with that plate.
1 - 3 of 3 Posts
