I did, no difference.Try unbolting the rim/wheel from the hub and flipping it around see if that makes a difference.
No, one valve stem hole, the other has no hole.I'm going to bet that you have two of the right sides put together. Look and see if you have a hole for the valve stem on both sides.
we need a picture of the wheel from both sides. Just wondering if you understood that dirtbkr188 was saying to take the rim and hub apart and put the hub on the other rim side.I did, no difference.
