1 - 3 of 3 Posts
I have been working on this for a little while and I cant do anything with it. I put a new piston and head on it and it is in time. It has decent compression (has not run enough on the new rings to seat 100psi now) I did a leak down test and it has very little leakage. The carb look good jets look clean can put wire through the opening. It does have a spark but not sure how good it is. I think it has to be electrical at this point but don't know where to start. The pulse coil was bent and I had to bend it back to get it to spark. Stator has .70ohms. I am at a loss. Any suggestions
make sure your pick up sensor is close to the little metal disc on the flywheel. A business card can be used to set the gap. Also, check for loose or corroded grounds on the CDI box. If that does not work, try a new CDI box. Good luck!
Discussion Starter #3
Sheared woodruff key on the flywheel
It was out of time. Wow would have never guessed
1 - 3 of 3 Posts
