1 - 1 of 1 Posts
Ok, I’ve been searching a while and can’t find anyone with the same issue or a fix for what I’m going through. 2020 CRF110. Tipped over bent the shift shaft, replaced the shift shaft. Watched the video on how to replace it exactly. Now here is my issue. Sitting in N and you click the shifter up should be in false neutral. But it actually engages 1st gear before you drop the shifter. Now you drop the shifter and can ride it like normal. But there is no N in between the gears. And for the life of me I can’t figure out why. Any information would be greatly appreciated
1 - 1 of 1 Posts
