I got this from the service manual. Check link.What weight oil do I put in this when I’m done? And, how much do I fill it? I want the forks stiff. Thank you!!! All advice recommended!!!
Different upgrade....Check link...Hello, I'm looking to upgrade the forks on my 2016 crf110. Thinking to go with the BBR dampening rods and springs but wondering how hard of an install they are to do. Also plan to do fork seals as well at the time and wondering how hard of a process that is. as for a rear shock is there a better one to go with then another?
Thanks in advance CP
It can't be that bad.Thanks for the reply! That's a little out of my price range at this point. How hard is rebuilding the stock forks with springs and rods?
Hi, I am installing BBR dampening rods and the BBR front fork springs…in my Crf110 2016 What weight oil do I put in this when I’m done? And, how much do I fill it? I want the forks stiff. Thank you!!! All advice recommended!!!
