1 - 9 of 9 Posts
I would like to have a bolt on shock mount for my XR/CRF 70 until I find out where I need to weld one on. I have a 9 1/2" elka with a 17 1/2" reeg swingarm. Let me know if you have anything that will work with my setup. Thanks
I don't think any bolt on ones will work
Discussion Starter · #3 ·
Then what do I need? A custom one or what?
I've Pm'd NCC about one and haven't got a reply yet. Looking to get this done fairly soon....
just cut the mount off......mock up the bike and set the ride height you want........semi tak/weld it inplace. make sure everything is good and finsh welding it up.
Discussion Starter · #5 ·
going to leave the original shock mount , since I'm always changing my setups and I don't think the original will work for a mono setup anyways. It needs to stick out farther off the frame then the a-style mount I believe.
You can leave the a-style shock mount alone. Here is a coupls of pics of what you need.
Discussion Starter · #7 ·
Sweet thanks for the help slow! is that shock the same length as mine? And do I need to get exact measurements to make it work good or can I go off your pics and be ok?
not sure how that would be able to run different swingers? the lower mount is in the way to run a hoop with shock. Also why did you support the mount like that? that frame looks stiff enough to be ok to just run the lower mount without the reinforcement.
That frame looks like a tank. but wheres the removanle subframe?.........I thought that was a must.....haha.j/k
looks good slow.
looks good slow.
That was the kit that reeg use to sell for a stock frame
1 - 9 of 9 Posts
