1 - 5 of 5 Posts
I have a question that i hope you guys can answer. I use me 50 for hunting, and playing but i want more power and would like to put an 88 or 81 cc kit on it. will an 88 or 81 cc kit make it run too hot when i'm just puttin around hunting. while hunting for the most part ill be doing 5mph or less and i could be going uphill doing 5 or less. will this make it over heat? if anyone knows i would appreciate the responce.
thanks
casey
Discussion Starter · #4 ·
i don't know, i hope i will find out next season...the bigger the better!!
Less compression
Hey Cowboy I think if you just get a kit without the high compression piston and run the right octane fuel and make sure your jetting is correct for the altitude you are at you will be fine.
1 - 5 of 5 Posts
