1 - 5 of 5 Posts
Will A Cooper Close Ratio 4 Speed Fit Into A Lifan 107cc Engine?
On Their Web Site It Says May Need Some Machine Work For Install. Is My Engine One Of Them? Any Info Would Be Great.
There is a thread around here somewheres that covers which motors use which tranny shaft setups. Short form, no I don't believe it'll drop into a Lifan 107 as it's designed to work with a primary mount clutch.
Banned
no it will not drop in.the shafts have to be machined and the cases need machined also.i use these trannys in my builds and its worth the time and money to make it work.the kick start gear is inside the cases like your typical china motor
1 - 5 of 5 Posts
