1 - 20 of 24 Posts
Its a little more involved than just jetting your carb for alky.
Alky will use about 2-3 times the fuel, Main jets +250 and pilot +80. You shouldn't have a hard time finding a carb set up for alky. The 5hp based Brigs and Straton Junior Dragsters have be running Alky motorcycle carbs for years and make good HP.
You will need about a +15:1 compresion ratio and advance the timing about +10*
Alky in extremely corrosive you will need to drian the fuel for the carb when the bike is not in use. Lot of maintenance.
Great info on web about alky conversion
But why stop there Go NITRO!
Good luck and keep us posted
I ran alky in my kart days....what a total pain but it does run cooler.
You do not need high compression but will need a slight timing advance.....more like
3-5 degrees ususally. It's a very expensive mod just because it is so corrosive.....I wouldn't do it. I'd either super charge or go nitrous....8)
dont bother trying to buy jets buy a numbered set of drill bits and a handfull of regular jets ps if you buy a tm 28 i can get you the info you need for jetting i used to race jr dragsters we ran those on a small motor we ran 44mm pumpers on our BIG motors
i ran 2/3 high octane gas and 1/3 40% nitro rc car gas in my xr100. it was definately interesting. i never had it tuned amazing tho. i just threw the biggest jets i had in and it was definately quicker. i did tune it a bit but not as much as i should have.
1 - 20 of 24 Posts
