The piston and rings for a 2000 mile street motor look almost brand new. The oil was only a little glittery which was probably from the aluminum that got smooshed up and ground a little bit on the rocker end. I have a magnetic oil plug and only a little bit of normal stuff there. I did recover one more, so that makes 3 found out of 16. If you think about it, there is no way it could go out the exhaust...there is no way to get it into the combustion chamber unless it passes the rings...and they did not pass the rings.
I have now completed the the thorough cleaning of motor and I can safely say I will not be finding any more of these things.
The motor is completely apart at this stage, so no flushing needs to happen. The motor is clean as a bean on the inside other than some slighly dirty oil. No residue so you can clearly see them. I even pulled the seals and looked in there. I pulled the clutch pack apart to make sure. They are not around.
Oil pump is fine, everything fine...I put parts in a box and blew them out with shop air...nothing. I have all the oil and all the carb cleaning solution I blasted into it. They are simply gone.
But here's the kicker...when it let loose, it was idling, and I turned it off within seconds of hearing the ticking caused by that slapping rocker. Seconds...they did not get ground up in seconds.
I wonder, just for a moment, if they got tossed around on the last oil change and dropped without me noticing. Then I ran it around a little bit and it just blew. But really, don't you think I would have found more?
