If I'm not mistaken you need to remove the cover on the other side of the motor and keep the flywheel from turning. The motor is still trying to turn over right? I think that is your problem. If not wait about 15 minutes and someone will correct me. An impact (air) gun would probably help too. Then it doesn't give the clutch an even force to try to turn. Might break it free before clutch could turn.
