1 - 2 of 2 Posts
I've got a little CT70 replica (Jincheng) that I'm having a clutch problem with. The bikes clutch won't slip when in neutral. If you stop with the bike in gear it stalls out like a manual clutch model that you leave the clutch engaged on. You also have to give it a little shove and knock it in gear or it stalls the motor. As long as you have the shifter down it's fine , but as soon as you release it it's gone. I haven't taken anything apart yet so what should I be looking for? Thanks
almost having the same problem here with my Z50R. Only mine's fine in neutral I can rev it out and everything with no movement but when put into first gear off it goes. Mine does however switch gears fine
1 - 2 of 2 Posts
