1 - 6 of 6 Posts
anyone have one of these clutchs New Classic Honda USA Auto Clutch.
This unit comes complete as a bolt in unit. Our new design incorporates 300% more clamping pressure and a heavier clutch housing for the higher horse power motors and heavier riders. they around $150 i want the engine kit thats the biggest i can use with the auto clutch. its nice to get off the big big and just click it into gear.
Discussion Starter · #3 ·
not that i know of , takegawa makes a closed ratio 3 speed to replace the stock stuff. 1st gear is supposed to be alot better and 2nd and 3rd are also a differnt ratio i belive
I have the Classic Honda Auto clutch... it works really well and it is easy to install. It is night and day difference over the stock, and I believe well worth the money if you want an auto clucth.
Just to let you know, Our 14 HP motor has a 3 speed auto in it. We beef up the clutch to work with this motor. No need for a 4 speed. We also change the primary gears. The most important thing with an auto clutch is to run 20w/50 oil. Our rule of thumb is: If you race it, you change it. If you ride the bike 3 hours you change it. Oil is cheep. Motors cost BUCKS!
We have had no problem with the clutch since we built the motor, so my answer to you is, Why spend 150 when you can have your clutch redone for 50.
Regards,
Jim
1 - 6 of 6 Posts
