Hey guys I bought a 20mm from tboltusa for my 110cc and I’m having a problem with the bike idling then going to wide open throttle almost instantly and it bogs and some times it bogs for a second then goes and other time it’s bogs and stalls. If I play with the choke I can make it run perfectly . My fuel mixture screw is almost all the way in currently with the slide needle as far in as it can go I’ve tried turning the fuel mixture screw out to give it more fuel and it doesn’t like that it bogs the same if not more so I thought maybe I should’ve just the needle but that doesn’t do anything, so does that mean I need to change the main jet? If so do I go bigger or smaller than my current main jet size? I’m open to retrying stuff I already tried if you guys have any advice. Thanks guys.
