1 - 2 of 2 Posts
Put a new carb on my crf 70 and it has a quite high idle. It is like someone is holding the throttle open. Adjusted pilot screw and nothing worked. I believe that the throttle cable has a kink and is not allowing the throttle sleeve to be as far into the carb as it should be. There is quite a bit of room. Could it also be that the air filter boot may have a leak? I’m uploading an image to get y’all’s opinion
Gas Fixture Nickel Machine Automotive wheel system
Crankset Bicycle part Finger Automotive tire Rim
1 - 2 of 2 Posts
