1 - 3 of 3 Posts
I have a stock motor and i heard if you move the needle on the carb down you can gain power.I put the needle down 2 notches and it feels like i gained bottom end but lost some top end is that possible or is it in my head??????
if you drop the needle it will lean out. You dont want it too lean though. If it takes awhile to idle down, then you need to drop the needle. On hot days you may need to lower the needle. On cold days you may be able to raise the needle because the air is more dense. But yah youre on the right track, drop it one clip at a time untill it runs funny, then go up one.
1 - 3 of 3 Posts
