1 - 4 of 4 Posts
I was looking at the 95cc cylinder and piston at dratv, and they said you need a stroker to make it work, but why would that be? will the 95cc cylinder work with the stock crank?
what is a good size carb for the 95cc? 22mm? 24mm?
Will an xr70 head or the 110 head fit on this?
Is the HRC head basically a 70 head?
not sure about the stroker crank, but im pretty sure you need to bore the cases out for anything over 88. the 22mm carb would be a good combo. the 70 head would work but you would need a domed piston also.
What Dr. ATV is saying is you can't use their stroker piston with the stock crank. Your compression would be too low, and the motor will run like poo.
For the proper 95cc combo, you'll need to bore the cases, have a 54mm cylinder, proper piston, and a good head, along with an uprated oil pump, and I'd run a 24mm carb and a good pipe, and a CDI box.
1 - 4 of 4 Posts
