1 - 8 of 8 Posts
i have a 18mm carb also, but I found a straight manifold at sik50s. its probably some ghetto old atc-sl-ct70-z50 manifold, because everyone knows that Honda re uses parts off other bikes.
i absolutely love the manifold, because what you said... I can still manage to use my sik50 frame brace.
I think those things are junk for changing the carb mounting posistion because they are either to far out or to far in and the carb hits the frame and the cable gets all jammed up under the gas tank they look cool for a manifold spacer though . And for a frame brace you could just use a prc frame brace for the big bore carbs like this one
[/img]http://www.planetminis.com/albums/P3RACING/Huracain_fiddy_pics_049.jpg
is this whats on the hanebrink set up, the filter is like the other freekin direction, looks kool tho, wonder if it ever gets in the way, well dont lay down your bike cuz it looks like it would snap off
ps. not speaking from experience just from seeing it
1 - 8 of 8 Posts
