1 - 3 of 3 Posts
Hello to you all,
I have a question regarding the dimensions of a S25 camshaft.
I have a Lifan 150 head with an original camshaft with bearings of 32mm and 35mm on the gearwheel side, next to this bearing of 35mm i have a machined space of 42mm. i would like to know the dimension of the S25 camshaft from bearing to bearing as i found out that the diameter of the bearings on S25 are 32mm and 42mm on the gearwheel side ( possible fit), so who can help me with the dimension of the outside to outside and the tickness of the S25 ?
Thanks , it would be a great help.
De_Stanny
1 - 3 of 3 Posts
