1 - 8 of 8 Posts
What are my replacement options and prices?
While I'm at it, I should probably grab an extra lever for my gpx/pitster disc brakes.
Oh, and my cuz needs a kx85 brake lever.
Links for where to buy are appreciated.
Thanks
I got a stock brake lever off my cr 85 that will work fo that kx 85. I have brake levers that cme off kx 85 on my cr 85 lol.
I also have my stock cr 85 clutch lever that will work with you tb clutch
Im running asv`s now lol
cable clutch perches and levers are close to universal, with the exception of the thickness of the pivot point. The hydraulic brake levers im not so sure about, without knowing the year of the bike or what pitsters run.
heres the basic asv clutch package, should last you a very long time-> ASV F1 CLUTCH LEVER / CABLE BRAKE LEVER | MotoSport
just punch in the make/model for the 85 lever and you should be all set.
Sorry but i cant really help ya on the pitster
Discussion Starter · #6 ·
Thanks for the advice... I was kinda hoping for a cheap replacement but it looks like I'll have to go with the asv f1.
Can't find it for cheaper than $53 shipped. Has anyone seen a better deal?
I've been riding the klx without a clutch lever (semi-manual)... I ate it pretty hard a couple days ago 'cause I didn't have the clutch lever to pull like I'm used to... :mad:
1 - 8 of 8 Posts
