brandxminis brake
554 Views 5 Replies 5 Participants Last post by  Mxrider346
Has anyone out there used brandxminis brake pedal? I'm thinking about buying one, looking for feedback before i spend my $50 bucks.
1 - 6 of 6 Posts
It looks quality but Im not fond of the design.Its going to hit depending on what footpeg bracket you run and has very little adjustment.Just go with the outlaw brake which is exactly the same as the sik110s except cheaper.
I have one and it didn't fit at all. I emailed them and sent some pictures. They said that their machining must be off and wanted me to send pictures to show what needed to be changed. They took care of me, returned all of my money and let me keep it. I did a little grinding and made it fit. They may have fixed it by now, but I'm not sure. It is nice other than the machining was a little off. If they fixed that then it is definitely worth the money.
Thanks for the info. I don't want to mess with it if i cant just bolt it on and go. I spend enough time working on my bike. I'll check out the outlaw brake pedal.
I know you have to space your pegmount down.
I have yet to have an outlaw lever just "bolt on" and go and make sure if you get one you reinforce the tacks on the pedal it snaps right off if you don't:D
1 - 6 of 6 Posts
