1 - 4 of 4 Posts
1969 Z50 K1, not running, with a fully charged battery. Key switch in first position, both front and rear brake lights work correctly. Key switch in second position, taillight is on, but goes off and no brake light when front or rear brake levers are pulled. Same thing with it running, except head light works correctly. What do I check first? THANKS!
Roger
Bad ground on tailight bracket/tailight housing. Bad will always cause that. Test with ohm meter.
Discussion Starter · #4 ·
It's fixed! Chain needed adjustment too, so I adjusted it and removed taillight, checked bulb ( OK), cleaned up all grounds and contacts, and put everything back together. Everything works as it should. Don't really know what I did, but it all works now! While I was working on it, another Sun City resident rode by on his 2019 Honda Monkey. He saw my Z50 and stopped by and we chatted awhile. It was a GREAT morning! Thanks again RAZZO
1 - 4 of 4 Posts
