1 - 14 of 14 Posts
I'm going to be buying a fifty pretty soon now and I want to get more power out of it, but I dont want it to be loud because then the neighbors get pist. Would it be bad to get a bore kit and keep the stock pipe? Also if I got a takegawa S-stage kit, is that all you need or do you need to buy more parts to make it work?
Itll still be pretty quiet though, nothing like adding a pipe, then it gets loud. And also, like Z88 said, screw the Take S-stage and check out the TrailBikes kits, way more bang for your buck.
Discussion Starter · #5 ·
If I got this bore kit can you tell me if I would need anything else other than an oil pump kit? This is everything that it has:
TB 88cc Bore Kit - 88-04 Models
88cc Big Bore Performance Kit (52mm):
- Lightweight aluminum cylinder with steel sleeve
- Cast in mounts on cylinder for aftermarket skid plates
- Oversized cooling fins on cylinder for efficient heat dissipation
- High compression 52mm piston with rings, pin, & clips
- Head gasket kit
Thanks a lot for all of your help!
I really recomend you look at the next model up, the one for $275, its actually a better deal because it comes with a 20mm carb to really let your motor breath and also a much more aggresive cam.
But aside from the oil pump the only other things you would need would be some HD clutch springs.
Then again, I just installed a TB 88 kit on my buddies bike with an oil pump, 20mm carb, race cam and race head and it rips! All of this for $448 and if you were going to be buying an expensive S-stage already. You should be able to afford this right? This will blow away an S-stage kit big time. The quality of this TB kit is just a good as Takegawa and Kitaco in my opinion.
Discussion Starter · #12 ·
Does anybody know if the BBR exhaust insert will fit into an FMF pipe. Also, if I got an aftermarket pipe and then later on down the road decided to get a bore kit would I need to replace my old aftermarket pipe with a "Big Bore" pipe?
1 - 14 of 14 Posts
