1 - 20 of 22 Posts
ok so my 07 klx 110 ran fine pure stock. Then today i bought a used pipe off a guy, only after market thing i have other than bars, its a two bros m6, its mint condition, put it on today and for about 20 mins it ran killer. Then i was hitting some small whoops with water in between in 2nd gear pinned and rigth when i came out and let off my bike started backfiring like crazy and then bogged and died. So i started it up, took a few kicks and after that just bogged like crazy, give it gas and it would die. Now i can't even get it to start. Im gonna go check the plug now, see what color it is, check the filter, and all the breather tubes. What else do u guys think? Talked to some guys out where we were riding and they said they didnt rejet there bikes when they piped them. I also flicked my on/off switch a couple times to see if it was working. And gas it on. Oh also it would run ok with the choke on. Help me out, thanks
Well if it runs okay with the choke on its lean usually what happens when you put a pipe on. You need to richen the air/fuel screw and most likely drop the clip on the needle. Shouldnt have to touch the main jet as its just a pipe. But def richen the fuel screw and go down a notch or two on the needle.
Discussion Starter · #3 ·
i was thinking it was the carb to, but i cant even get it to start. If its not jetted right it will still run just not good.
Discussion Starter · #8 ·
ok the air filter was dry cause its the stock sytem, but i just pulled the stock air system off cause i thought maybe somewhere where it pulls the air is clogged cause it would run with the choke on and after i pulled it it started right up! but a min earlier it wouldn't! So i ran it up the street and it was fine! So somehwere the air is clogged. Also wheres the air screw, i feel like a douch asking but i can only find the idle, lol
if you have a 07 110 the screw doesn't exactly look like a screw. it had a weird head on it... you can usually take it out and cut a slot in it with a dremel so you don't have to use the special kawi tool
1 - 20 of 22 Posts
