1 - 10 of 10 Posts
looking to upgrade the drum kx60 brakes on my perimeter to disks in the rear. Whats the best wheel and brake setup that wont cost me a fortune , i really like burchs formula but he told me there was better. So let me knw what will be best.
Discussion Starter · #4 ·
well my bro has the bbr wheel with tht setup and its really heavy , i dont wanna pack on a ton of weight. Burch told me to run the rad wheel but i was also looking at the talon
The RAD Econo is nice, and I believe it uses standard KX65 bearings, spokes, rotors, and sprockets. Or powdercoat a stock KX65 hub. Then get a light aluminum Excel for it in whatever color you like. Do you already have the BBR master cylinder mount? I think that's the only one that works on the perimeter frame. Maybe the BigMini's too.(if you can find one). Then get a stock KX65 master cylinder & caliper, and STR's caliper carrier & extended line (pick your color), and you're set.
Wait, the BBR perimeter frame already has the master cylinder mount on it right? What's the hole spacing? You might have to use the BBR master. It might be the only one that fits on that frame. I'll measure a KX master's hole spacing so you'll know what options you have there.
PS: FasterMini's had the BBR disc brake system on "Killer Deal of the Half-Hour" TWICE today for $371. (Usually $530)
Discussion Starter · #8 ·
geez 371 thts not bad , can tht be used wit any wheel
Discussion Starter · #10 ·
i wonder if i could put tht hub in my kx60 wheel ?
1 - 10 of 10 Posts
