1 - 5 of 5 Posts
TB parts has the same thing, and your getting it from a reputable source. Also they sell the entire basket.
Heres the link to the clutch plates
Honda Trail Bikes
Heres the link to the entire clutch basket
Honda Trail Bikes
Note CT70s use the same parts as the TRX70 does so this should work/fit no problem.
You can also go with a manual clutch from TB parts if you would like, and it will come with everything you would need.
If you're running the stock motor, I would suggest OEM Honda plates and springs. Can't go wrong with them as far as durability is concerned.
Discussion Starter #4
i havent taken it apart yet, but i kno its shot, would it be wise to buy the basket and plates and springs? or just plates and springs? this is my first 70 thats why i have all these questions, haha
I'd say tear it down first, inspect, then decide what you need from there. The pressure, drive plates and basket, if ordered from Honda, can get a little expensive. But those parts may not need to be replaced. I'm sort of a purist, so I'd buy all Honda, but if it gets outside of your budget, the TB clutch will suffice just fine.
1 - 5 of 5 Posts
