1 - 11 of 11 Posts
I'm going to put in my bbr 143 bore kit in my 2005 klx 110 this week. Right now i just have everything stock in the engine, other then a t4 pipe and an exposed air filter.
Will it make a big difference if i just run the stock carb compared to a 26mm? Should i worry about the output shaft and other small things inside the engine?
If you dont have the output shaft try two things to make it last longer. Get a bumpstart kit and start it without the kickstart or push the kickstarter down 1/2 half before pushing down hard to start. It works on big bikes I am told.
You can't bumpstart an auto.
1 - 11 of 11 Posts
