Just got a XR75, its a 79 frame with a 74 motor. Motor was professionally rebuilt, but the bike was reassembled by someone else, so the engine builders were not able to tune the carb.
So now I have it. Not sure if the carb is original or aftermarket, it looks newer then a 40 year old carb, but looks like the original based on the pics in the manual.
So this is were I am at, bike starts and runs, and will idle...but will bog when giving it a little bit of throttle, and wants to stall out, then if you get going faster and give it more then 1/2 to 3/4 throttle it will not gain power and sputter. The other thing it will do is not start with the choke on, even if cold, and will immediately stall if you flip the choke on once its running, not sure what that means. I tried setting the idle and air screw per the manual, but it did not seems to help.
thanks for any help
thanks for any help
