After running my lifan 107 on the atc70 in the sand and having it lose half its power after about 10 minutes I would like to mount an oil cooler to my piranha 140 when it gets here. I am thinking best place would be at the number plate/infront of the forks; but not sure if the oil pump has enough power to pump the oil that far and back?
Where else are you guys mounting them at? Also are any of the coolers any better/worse then others?
@T Bolt USA Any recommendations from your website?
