1 - 20 of 53 Posts
So I purchased a cdi igniton for my atc off ebay from malyasia and they said it would take 21 days to receive it . 21 days later the mailman dropped it off and i had to install it asap! haha ! It took flywheel puller and 2 screws and my old o-ring off my stock ignition. connected 3 wires and BAM ! started right up ! Ran real rough until i rejetted and adjusted my carb but now i think it has more throttle response. I put it on my stroked and bored 70 engine with no issues!
I highly reccomend this kit!
yeah the oil seal runs about 10 bucks dont forget to pick one up. did you guys have to rejet? mine wont run strong up top but i need to get some maintenance issues taken care of first. could i have just ran and irk instead?
G
I just installed two of them. They work great and give a noticeable increase in power in the upper rpms. The biggest issue I had was trying not to pinch the stator plate o-ring upon installation. Before installing, I used a small file to deburr the edges of the plate and the o-ring groove. The casting is a little rough as received. Also, I found it was much easier to take everything off the plate and install it bare with plenty of lube on the case and o-ring. I used the two stator plate screws to incrementally pull the plate in evenly while tending carefully to the o-ring by tucking it in with a small screwdriver whenever it started to pinch. Once installed, it fired right up.
1 - 20 of 53 Posts
