1 - 3 of 3 Posts
· Premium Member
It looks like we are re-auctioning this one of a kind Apollo RFZ Elite Pro. IF you missed it last time, you've got another chance!
Auction begins 8/28/2015
on ebay now! click the link below
http://www.ebay.com/itm/331640364081?forcerRptr=true&item=331640364081&viewitem=
The only one in world!
Special customized Apollo Elite Pro with large frame and Daytona Anima 190 engine. Professionally built at Wholesale Cycle.
We buy samples of bikes from around the world and fly them in for testing and development. This particular machine has about 15-30 minutes of run time and is almost new. This RFZ Elite Pro has the larger frame to accommodate the Daytona 190 engine and clear the front wheel. This is your chance to own a true one of a kind Pit bike from a world class builder.
Land vehicle Vehicle Motor vehicle Motocross Motorcycle
more pictures can be seen at ebay by clicking the link below
Other Makes RFZ Elite Pro | eBay
Spec
150 ELITE PRO
Engine
Engine type
Single Cylinder,4stroke
Displacement:
186cc Daytona Anima
Transmission
manual
starter mode
kick start
Ignition:
CDI
Cooling system:
oil cooled
Carburetor:
KEIHIN. PE28
Chassis
Fork
Double Adjustable 770mm
rear suspension
Adjustable 360mm
braking system
Hydraulic Disk
Handlebars:
alloy 28mm
F/R Hub
CNC
F/R tire barnd
Kenda
F/R Rim
alloy
Front tire
60/100-14
Rear tire
80/100-12
clamp material
high quality CNC
frame
Tubular twin Frame
Seat cover
material made in Taiwan
Dimensions
seat height
830mm
GW/NW
81kg/71kg
· Premium Member
Discussion Starter · #2 · (Edited)
1 - 3 of 3 Posts
