Take them to your local atv dealer and let them do their magic with the tire machine ....... seriously.Thank you for all the info! Next question is what is the trick to un mounting and mounting tires?!![]()
SS LS1, have you had any issues with the axles bending running the wider/larger wheels? I want to ride up on two wheels but worried the extra leverage is going to cause issues.Here are the setups I run today both with Douglas 8 x 7 race cut wheels which is plenty wide for a 70.
Sorry for the late reply..... no I have not had a single problem with bending anything from axles to hubs or wheels hitting bumps or riding on two wheels. I ride the snot out of my 70's from sand paddle shock loads to hard core ditch riding and still not a single problem. Plus I'm a big guy at 6' 4" 250 lbs so no featherweight rider either.SS LS1, have you had any issues with the axles bending running the wider/larger wheels? I want to ride up on two wheels but worried the extra leverage is going to cause issues.
Hello can you tell me what size tires that are the orange atc with the tread in a arrow pattern front and rear. ThanksHere are the setups I run today both with Douglas 8 x 7 race cut wheels which is plenty wide for a 70.
Braaaap!
Do you like the zippers or the paddles better for Silver Lake? Im trying to get mine ready for Memorial Day Weekend.Typically I run a 18 x 7 - 8 Maxxas for the front. The red 70 above with the 350x had a Duro 18 x 7 -7 and a 7" Xowner front wheel. Have run an 18 x 7 -7 Duro Thrasher front tire that rode fantastic as it is a 2 ply radial tire. I have one brand new one if you are interested.
For front hubs I am running the Spangler's billed 4 bolt hubs and aluminum axle spacers to save weight.
Maxxis 18" front and rear tires.... personal favorites
Duro 18" tires on orange trike.
Maxxis vs Duro
Braaaap!
