1 - 7 of 7 Posts
I picked up a sikk 120 motor today for parts... and just by looking at the parts I can tell its a lot different than a lifan 120. This is the stuff I noticed right off....
-head appears to be something similar to the stock GPX with the smaller valves
-the studs are honda diameter... not bigger like the regular 120's
-stud spacing appears to be goofy still... but its hard to say without measuring it yet.
-13mm wrist pin unlike the regular 14mm units
I will get more specs tomorrow just for kicks. Chime in if you know any other quirks.
Discussion Starter · #3 ·
That sounds more like the crank mounted clutch 125 motor?
I'm talking about the newest style with the clutch on the main shaft. This particular motor had a bearing go for the transmission. I believe it was doing the whole false neutral thing as well. Its tempting to replace any bearings it may need and run it... but I have a feeling I would regret it. I bought it for the stator/flywheel and random tidbits that will carry over to a honda build.
Looks like the head will bolt right up to a honda build. Might only be able to run one dowel pin without reworking the other one. The tooth count on the cam might be different as well.
TheCRKid said:
so far all the 120cc steel barrel motors
-unique stud pattern
-14mm pin
-big valves
prolly forget some stuff since its been a while
Thats sounds about right except you forgot they have glass transmission shafts and play-doh gears
Discussion Starter · #6 ·
So i finally got around to doing a little measuring yesterday on this engine. It appears to run a 57mm stroke with a 13mm pin like a GPX. It has the smaller valved head like the GPX too. I think its a knock off knock off motor.
The only part that confuses me is the smaller diameter studs? I slid my stock RCM (zonger 120) cylinder on the studs and it went on fine. It has regular 120/125 spacing with honda diameter studs. I guess it just wont be as strong of a top end as a motor with the thicker studs?
This crank might find a new home in a set of zongshen cases...
Vendor
o im sorry
you mean the new sikk mx motor
there very similare to the gpx
but lack the best trail ,,,,4up trannys
atleast with a lifan 120 its shifts bad but has the big valve head
1 - 7 of 7 Posts
