1 - 2 of 2 Posts
also would like to know what gas and oil should i use to start up the motoped for the first time i got 49 cc on it.
The Motoped 50cc Lifan engine is full auto, single ratio transmission that uses 2 clutches that engage at different engine speeds so you just gas and go. Most Lifan 50cc replacement engines you find listed for sale on-line have a semi auomatic clutch and multiple transmission ratios, either 3 or 4, which shifts like a regular motorcycle except there's no clutch lever required to manually operate.
Here is a link to the Motoped owners manual with reccomended gas and oil. Just make sure you use an oil that is made for motorcycles. If you use an automobile oil that is labeled "energy conserving" it may contain friction modifiers that can make your clutches slip and they will never function properly even if you switch back to the proper oil.
https://motoped.com/Motoped_Pro_Owners.pdf
1 - 2 of 2 Posts
