1 - 20 of 55 Posts
Picked up another road legal clone locally for 400, and then shortly after found a complete yx170/superhead engine with exhaust/wiring/kick/shifter/carb etc for only 250 secondhand and thought I'd build something silly!
How she looked when I got her! Ugly!
273513
Picked up a rear fender, and chucked on an old black pair of forks I had (will be converting to disc brake front soon)
273514
Second hand yx170 with superhead.
273517
Dropped in nicely, I was worried about front wheel clearance but no problem at all! Also threw on the 120/70 Duros, still waiting on some aluminium wider rims, went with 3.00 front and 3.5 rear.
273516
Smaller bars and seat wrapped in some scrap faux suede.
273518
Tank painted white, only a quick 2k rattle can job, good enough for me.
273520
How she sits atm.
273521
Still need some other bits, smaller rear sprocket for sure, currently 19/28t.
Also can't decide wether to go with z50r decals or the baja monkey decals!
273522
Weird, I just picked up a 170 with a super head too for my build. Didn't get as good as a deal as you did tho.
I'm with Niels, on that one. Any chance you can add me as a beneficiary on your life insurance? You're going to be way more comfortable and happy with a longer swinger. Just pick up an XR80/XR75 one!
Also, Duro's are great, I really liked mine.
Discussion Starter · #5 ·
That is weird! What bikes it going in?
Believe me I did think about a longer swingarm but after riding it's really not as bad as I thought! The taller gearing helps keep the front end down, if I did extend it would only be a +1
I think my electric pit bike conversion also makes this bike feel not as wild as I'd imagined 😂😂 that thing lifts the front like no tomorrow
The Duros are great! A little more expensive but I like them a lot!
Discussion Starter · #8 · (Edited)
Fitted the alloy rims, nothing crazy only 3.0 front 3.5 rear, slapped on some old honda stickers and took for a quick spin.
273546
273547
273549
Thinking of lowering the forks a touch 10-20mm and wondering the best way to go about it? Is it possible to simply cut the coils or better off chopping and re drilling the chromed fork legs?
Discussion Starter · #10 ·
Discussion Starter · #12 ·
Daytona makes shorter legs too. (with dampened inserts)
Congrats on 2000 posts!
dampened inserts would be so nice! but more than im willing to spend haha
Does anyone know if the regular lower forks kits are shortened via the chrom stanchions or by the spring length?
Discussion Starter · #15 ·
Got the rims fitted, nothing crazy just 3.5 rear and 3.0 front, also got a new rear sprocket, lowest I could get is 25t. Slapped on some temporary honda stickers.
Took her for a quick test ride and top speed is at exactly 70mph on gps, I expected more seeing as my last bike had the same gear ratio yet managed 77mph on flat ground with a yx140, I can only think the carb on this 170 is restricting the top end a bit.
Tire Alloy wheel Rim Wheel Automotive tire
Tire Motor vehicle Automotive tire Wheel Vehicle
Alloy wheel Wheel Rim Auto part Tire
Land vehicle Vehicle Motorcycle Car Motor vehicle
What carb are you running? I'm going to be following this closely, as I mentioned I picked up a 170 recently as well. Idk if I'm gonna throw a 25T on my Cub but I like your style.
If cutting the fork legs to lower, just be sure to redrill the hole that the split pin goes in that holds the spring to it in the right location. I got a pair of legs off a 197? Z and the hole was 90° different.
And here is my dirt beater with a +1.5” swingarm. Every little bit helps if you plan on higher cruising speeds.
Discussion Starter · #19 ·
Too too fast for me, but I dig it!!!! Bike looks great.
thanks buddy!
haha 25t on a cub! im not sure what the carb is or what size, id imagine a 26mm, the inlet valve on these engines is 28.5mm i think so unsure whether to go with a 28mm or 30mm (i was running 28mm on my last yx140)
Thanks for the headsup! I did notice that the split pin holes aren't even drilled directly through the tube, they're slightly offset too, chinese I guess!
That bike looks awesome! perfect geometry! If I do extend the swingarm I think I'd only go +1 but that 1.5 with the wheel slammed would be spot on!
Discussion Starter · #20 ·
Picked up a front disc fork kit, the caliper it came with seems pretty big and heavy but works nicely I might change later if I can find something smaller.
Had to swap the rim direction hence the from tyre on backwards.
Land vehicle Motorcycle Vehicle Motor vehicle Automotive tire
Tire Automotive tire Wheel Motor vehicle Spoke
1 - 20 of 55 Posts
