Hi everyone. I'm new to this forum and wanted to see if anyone can help me with an ignition problem.
I have 1984 ATC70. I rebuilt the stator, new points and condenser, new ignition coil. The bike was running fine until the other day, I started it, it spit and sputtered and wouldn't start again.
It has no spark. The black ignition wire has continuity to ground even when the points are open. If I remove the ground from the exciter coil the continuity goes away when I open the points.
Does anyone know if the condenser could be my problem? Can it go bad and short to ground?
I appreciate any help. Thanks.
