So I have a 71 K2 Z50 , i have hooked wires up per wiring diagram, all stock harness . I do have after market stop tail and headlight. Problem is tail light is super bright and when I use a brake lever , light goes dim. Should be other way around. I checked the leads to each filament and switching the leads do not make a difference, I have check ground to frame and seems solid. Any thoughts ?
