1 - 3 of 3 Posts
same as last thread with correct price
Motor needs assembly, complete with al lelectronics and key, ran excellent and every part inspected. only thing needed is gasket kit and its ready to run. never ran on upgraded parts (lifan head was slightly used), ct crank with shorter rod to run correct piston, kitaco oil takeoff plate. completed pictures are simply mock up and was disaasembled for inspection and install correct crank, cr80 kickstarter. will accept paypal or local pickup
located in calimesa ca 92320,
[email protected]-paypal
http://i28.photobucket.com/albums/c214/zbbt/DSC01217.jpg
54mm aluminum cylinder
lifan BVH with new z40 cam and correct springs
Manual clutch kit.
two new pistons 1 low compression one high compression
cases pre-bored for 54m m cylinder.
Brand new OKO 26mm carb with two different intakes.
motor on right
1 - 3 of 3 Posts
