1 - 2 of 2 Posts
Getting ready to pull the trigger on the tbparts 88cc kit w/ Shengway carb for my 72 z50a.
I wasn't planning on buying the race head kit, because i've rebuilt my factory head and it's in fantastic shape.
While browsing DrATV I notice a performance cam w/ roller bearing and some upgraded valve springs.
Would there be any benefit to adding this cam and springs to the standard 88cc kit with stock head?
If so, would it be compatible with the 88cc piston due to the increase lift?
Links are below. Feedback would be greatly appreciated!
BEARING_TYPE RACE_CAM Z50_TO_1981 ATC70_ALL CT70_TO_1981 PASSPORT_80/81 TRX70_ALL XL70_SL70_CL70
HEAVY_DUTY VALVE_SPRINGS WITH_WIDER COIL_SPACING FOR_HI_LIFT_CAMS IN_50_70_HEADS (GREAT_STOCK_REPLACMENT) (200149)
For that price why not? Im sure the only difference you would feel is instead of falling on its face higher up in the rpms it would just continue to pull as it did in the mid range.
1 - 2 of 2 Posts
