Does anyone have experience swapping a 1987 XR100R motor into a 2003 XR80R frame? Curious if it bolts right up so I can modernize this thing. Thanks
Hey thanks there, yessir it bolts right up and fits well. I'll post pics at some point. Tough part is now the ignition. The coil and brackets aren't the same and ots all different. 1987 (top right in the pic below) doesn't have a CDI, I guess?Looking at microfiche diagrams for both models, they seem to use the same engine mount bolts and brackets, and use the same swingarm bolt, as well. Only one way to find out for sure, and that's to pull the engine and try it in the 80 frame.
I do know that you can use a 100 top end on an 80 lower end, so the frame clearance with the valve cover should be the same.
