1 - 4 of 4 Posts
i have a similar issue with my 87 trx atc125m i have two yellow and a red/black coming out of my stator.i have changed everything i can think of and still cant get fire from it,i even double checked the wiring just in case it has a cut or nick
· Administrator
HERE is a wiring schematic, if it's any help to you. Looking at it, there should be a blue/yellow tracer wire coming out of the stator harness as well, that's for the pulse coil, which is part #4 shown below.
Font Ear Auto part Circle Drawing
i have a similar issue with my 87 trx atc125m i have two yellow and a red/black coming out of my stator.i have changed everything i can think of and still can't get fire from it,i even double checked the wiring just in case it has a cut or nick
The 2 yellows are your charging coil leads that go to the regulator and charge your battery and the BL/R wire is the lead suppling power to the CDI box. There should also be a Trigger (Pulse) coil with 2 leads (most likely one is green).
1 - 4 of 4 Posts
