installed a ogm 160 into 82 ct 70 and have it up and running fine but have not connected either of the two yellow stator wires to anything. would like to get the lights working. ordered a 12/6/volt regulator and have looked at some examples of how to hook it up but have not had any luck. it does produce good ac voltage across the two yellow wires out of stator. I used the connector off the 70 stator as the connector for regulator ,then tied them in to the harness as illustrated in the examples found. it says to retain stock battery for 6v. I only get about two volts at battery. any suggestions thanks phillip
