Hello,
I'm new on the forum but look forward to contributing and learning as I begin to work on a few z50's.
I bought a 79 z50 recently and it wasnt running which is ok because i plan to fix it up and learn then ride a lot. I have the manual and have been reading it several times. I checked for spark against the block and it sparks well. I opened the carb drain and it gets gas. It has compression but ive not a compression tester, yet, i can just tell. Still wouldnt start.
This lead me to believe that perhaps the timing is off after reading posts online and the manual. So i learned how to tweak the timing. As i learned to tweak the timing the 1st try i did it wrong and didnt gap the points appropriately but somehow lucked out and on the 1st kick it ran! This lead me to find other problems (prior owner put in wrong throttle cable which was too short leading to extremely high rpms when choke off).
Anyhow, the bike all the sudden wont start anymore. I went back to the timing, bought a feeler gauge, and reset the timing appropriately (it begins to open at "f" and is open at "t"). I se tthe gap to the manual's spec (.3mm i think it was).
So now, i have spark, i have compression, i have it timed, and i have gas. Short throttle cable aside i should be able to start this thing like it started before. I also know it runs because it ran before by luck of playing with timing.
My question: is there a way to determine if my condenser, points, wiring inside the flywheel, or any of that is bad using a multi-meter or eyeballing it while it runs (if i can get it to run again) or something? I'm about to take the flywheel off and potentially replace the points, condenser and all the innards but perhaps it is not necessary.
The points are flat, clean, and contact well and open well. I did see a somewhat melted wire at the bottom right (see attached pic) but the wire is still strong and it looks like someone wrapped electrical tape on it last time they had it open. Maybe that's shorting something? i think it was the the wire that exists the case via solid black wire to the coil.
