You can also use one of these for soda blasting:Siphon Spray-Cleaning Blow Gun - Made For Use with Liquids - 150 PSI
That looks great. Can you post a more detailed pic of the air gun set up? I would love to try that method!I made a soda blaster using 3/8” ID tubing, a plastic cup and lid from a convenience store, and a air blow gun. It worked pretty well and it cleaned the head in about 5 minutes using 3LB of baking soda for a total of $2.40.
I rinsed the head in hot water after, then heated it with a heat gun to dry it, and lastly put oil on the valve guides and combustion chamber. Looking back I’d skip the wheel cleaner next time and go straight to the baking soda.
The idea was something I saw online and I just used what I had to put it together.That looks great. Can you post a more detailed pic of the air gun set up? I would love to try that method!
Thanks
Wow, that clutch has taken a bit of a shock somewhere along the line. I just took mine apart today. Needs new friction discs, but that's all. Did you use the Honda flywheel puller to get the other side apart? I tried with a homemade puller, but no luck. I'm going to have to find the correct one, I guess.I had some time and rebuilt the stator. Does the seal on the stator plate go in with the spring side facing toward the inside of the engine ?
I spent what felt like forever cleaning the gasket material off the inner case mating surfaces. One of the transmission bearings was notchy, I have two on the way.
I opened up the clutch to clean it and put in new discs. I found the inner splined hub broken, Honda part number 22120-040-030. I’m glad that I opened it up and found it now. Anyone have an extra one they would like to sell? View attachment 274818 View attachment 274819
Correct flywheel pullerI'm going to have to find the correct one, I guess.
I do have one of the flywheel pullers, worth the few bucks. I ordered a used clutch from eBay to get the replacement splined hub and other parts I may need in the future.Wow, that clutch has taken a bit of a shock somewhere along the line. I just took mine apart today. Needs new friction discs, but that's all. Did you use the Honda flywheel puller to get the other side apart? I tried with a homemade puller, but no luck. I'm going to have to find the correct one, I guess.
