bore size
I appreciate your response. I went to a machine shop yesterday afternoon. They weren't all that familiar with vintage motorcycles, or all that pleasant to speak with, but they did have lots of bore knowledge and micrometers. The guy there believes it has been bored 1 over, which he argues may be the reason for a number 1 on the piston. The 153 number we both think means its just a Honda piston. I checked the engine number like you said and the 7th digit is in fact a four.
I'm still a bit confused. I thought being bored 1 over meant it was bored 10-thousandths (.25mm) of an inch over stock. The book tells me the largest stock piston skirt should measure 46.99mm. Adding .25mm to that just brings me to 47.24mm, not the 47.95 I measure with my caliper. That would be more like 0.96mm difference, which is more like forty-thousandths of an inch over stock size. I'm still lost and apparently have lots yet to learn about boring. I was hoping someone on here had been down this road before.
I'll measure the cylinder with my caliper tonight. I'm still trying to find a bore gauge locally.
the way it works from imperial to metric
.25mm is .010" 10 thousandths over {first over size}
.50mm is .020" 20 thou over 2nd
.75mm is .030 30 thou over 3rd
1.00mm is .040 40 thou over 4th
measure the top of the barrel and the bottom of the barrel and post the results in mm
that will tell me what the bore size is std or oversize
the old piston could be worn or the skirt may have collapsed in size due to overheating
the bore size is what you work off first then check the piston for clearance this will tell you if you need to re bore or get away with a set of rings these old XRs most of the time will be ok with new set of rings even if the clearances are at there max
hope this helps
