Paxracing said:you can not run that cylinder in vegas stock class
Paxracing said:we are doing motors for vegas stock class 70 piston in the 50 cylinder and have to cut the top of the piston to work.
How is he cheating? Says nothing about a piston or boring the cylinder. Its basically a stock appearing class. As long as its the stock head and cylinder anything goes. Hell you can even stroke the stock crank which PAX does. theres gonna be some serious motors in the stock class this year.melloyello said:Why cheat?
MMStock - This Class is for STOCK XR/CRF50 or TT-R50 Motorcycles Only.
The following items must remain “Bone Stock”: Engine, frame, swingarm, forks, shock, rims, spokes, hubs, carburetor (re-jetting is OK), complete ignition system, seat (covers can be changed, foam must remain stock), footpeg mount, brakes, fuel tank.
Bikes can be modified by changing or adding the following parts: Upper tripleclamps, handlebars, grips, brake cable, throttle cable, kill-switch, throttle assy, brake lever, sprockets, graphics, tires, exhaust system, air filter, fork springs, shock spring, chain, footpegs, skid plates, shifter, plastic (ie: fenders, shrouds, number plates can be replaced in color only - must have white backgrounds).
cyclerider57 said:I shouldn't be saying this but seeing how I can't go I don't have a reason to hide it... 47mm isn't the maximum on a stock cylinder.
ryan2282 said:How is he cheating? Says nothing about a piston or boring the cylinder. Its basically a stock appearing class. As long as its the stock head and cylinder anything goes. Hell you can even stroke the stock crank which PAX does. theres gonna be some serious motors in the stock class this year.
